Salta al contenuto principale
Heyday Wireless Speaker 8125 Grille Replacement
Cosa ti serve
  1. Heyday Wireless Speaker 8125 Grille Replacement, Grille: passo 1, immagine 1 di 3 Heyday Wireless Speaker 8125 Grille Replacement, Grille: passo 1, immagine 2 di 3 Heyday Wireless Speaker 8125 Grille Replacement, Grille: passo 1, immagine 3 di 3
    • Orient the speaker so that it is sitting upright.
    • Use your nondominant hand to hold the speaker in place while you firmly push the plastic spudger into the seam between the device wall and the grille.
    • Push down with the plastic spudger and lift the grill until you feel it separate from the speaker.
    • Gently remove it from the top of the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 61
