Salta al contenuto principale
Heyday Wireless Bluetooth Speaker 9979 Volume Technique
Cosa ti serve
  1. Heyday Wireless Bluetooth Speaker 9979 Volume Technique, Heyday Wireless Bluetooth Speaker 9979 Volume Technique: passo 1, immagine 1 di 1
    • Remove the 4 circles from the wireless speaker's back using the metal spudger. Try to get under the circle using force and pull it out little by little.
  2. Heyday Wireless Bluetooth Speaker 9979 Volume Technique: passo 2, immagine 1 di 1
    • Remove the four 1.6mm Philips screw #1 with a mahi kit driver. Rotate the driver counter clockwise to remove the nail.
  3. Heyday Wireless Bluetooth Speaker 9979 Volume Technique: passo 3, immagine 1 di 2 Heyday Wireless Bluetooth Speaker 9979 Volume Technique: passo 3, immagine 2 di 2
    • Remove the cover of the wireless speaker using the metal spudger. Don't use much force to remove it.
  4. Heyday Wireless Bluetooth Speaker 9979 Volume Technique: passo 4, immagine 1 di 3 Heyday Wireless Bluetooth Speaker 9979 Volume Technique: passo 4, immagine 2 di 3 Heyday Wireless Bluetooth Speaker 9979 Volume Technique: passo 4, immagine 3 di 3
    • Remove the motherboard. Hold the motherboard from the right corner. Turn the motherboard facing you. Press and hold the button all the way on the right of the motherboard. A light should turn on, which means the speaker is on.
  5. Heyday Wireless Bluetooth Speaker 9979 Volume Technique: passo 5, immagine 1 di 2 Heyday Wireless Bluetooth Speaker 9979 Volume Technique: passo 5, immagine 2 di 2
    • Press the second button all the way on the left, and keep pressing it until you are happy with how loud the volume is.
  6. Heyday Wireless Bluetooth Speaker 9979 Volume Technique: passo 6, immagine 1 di 3 Heyday Wireless Bluetooth Speaker 9979 Volume Technique: passo 6, immagine 2 di 3 Heyday Wireless Bluetooth Speaker 9979 Volume Technique: passo 6, immagine 3 di 3
    • Once you are done using the speaker, press and hold the button all the way on the right to turn it off. The light will go away and that's when the speaker will be off. Lastly place the motherboard back into its place through those skinny lines.
Conclusione
After taking out the motherboard and fixing the buttons, you should be able to slide the motherboard back into the slot. After you should be able to put back on the top and reassemble your device.
Chris Yepez
Membro da: 09/26/22
233 Reputazione
1 Guida realizzata
5 Commenti
I think this guide is pretty good, a recommendation I have would maybe be more specific when symbolizing some of the steps (with circles/ arrows). An example would be on step 4, so that the user knows exactly which button to press.
Diego - Replica
Thank you, sounds like a great recommendation.
Chris Yepez -
One image was not very clear because the finger was taking up the frame too much.
Cindy Munoz - Replica
The guide is great overall, I'd recommend that you space out or separate the instructions on steps 4 and 6 (they feel too cluttered and could be more appealing to look at). Besides that, it's a great guide.
Hector Felix - Replica
Thank you for your feedback!
Thanh Duong -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 226
