Salta al contenuto principale
Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement
Cosa ti serve
  1. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement, Hinges: passo 1, immagine 1 di 2 Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement, Hinges: passo 1, immagine 2 di 2
    • Bend the headset so that you can see the 1.2mm screws that need to be removed before removing the hinge. Next, take a hold of a Philips screwdriver size 00 and remove the screws.
  2. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement: passo 2, immagine 1 di 1
    • After removing the two screws, you can replace the hinge by removing it from the wire.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 93
