Salta al contenuto principale
Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement
Cosa ti serve
  1. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement, Headband: passo 1, immagine 1 di 2 Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement, Headband: passo 1, immagine 2 di 2
    • With the opening tool, pry the plastic tabs that hold the headband to the headphones outward. Remove the plastic tab on both sides of the headband..
  2. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement: passo 2, immagine 1 di 2 Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement: passo 2, immagine 2 di 2
    • The headband itself is held in by four 1.2mm screws where the tabs were. Remove the screws with 00 Phillips screwdriver.
  3. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement: passo 3, immagine 1 di 1
    • Push outward and in your direction with the opening tool to separate the headband from the headphones. Replace by following the directions backwards.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 62
