Salta al contenuto principale
Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement
Cosa ti serve
  1. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Ear-pad Cushion: passo 1, immagine 1 di 2 Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Ear-pad Cushion: passo 1, immagine 2 di 2
    • Position the headphones so that you can see the opening for the cushion as you take out your blue iFixIt opening tool. In between the earpad cushion and the headset, place the iFixit opening tool.
  2. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: passo 2, immagine 1 di 1
    • The connectors that the cushion snaps into place are used to attach the cushion to the headset. The connectors could be damaged by applying too much force, which would prevent the cushion from returning to its original position.
  3. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: passo 3, immagine 1 di 1
    • After the earpad cushion has been disconnected from the connectors you can take your new earpad cushion and install it.
  4. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Battery: passo 4, immagine 1 di 2 Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Battery: passo 4, immagine 2 di 2
    • After removing the ear pad cushion, unscrew the four 1.6mm black screws with your Phillips-head screwdriver.
  5. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: passo 5, immagine 1 di 2 Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: passo 5, immagine 2 di 2
    • Use the Phillips-head screwdriver to remove the black casing screws.
    • Lift the casing to see the battery.
  6. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: passo 6, immagine 1 di 1
    • The central spherical piece of metal is the battery. Use the ifixit opening tool and pry open the battery in your direction to remove the battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 111
