Introduzione
Do this at your own risk. This battery is dangerously soldered down, so replacements can be difficult, and is only for those who have experience with soldering.
Cosa ti serve
This particular model is 64GB
Do not operate on this device if:
The battery has swelled or expanded
The battery is hot
The battery is charged (drain the battery before opening)
The battery has been punctured
The battery has leaked
The device is warm or hot to the touch
Use the pointed tip of your metal spudger to unscrew the 2 screws
Make sure to replace the circuit board protective film during reassembly
Here's MicroSD card that you can upgrade if you want!
Pause here if you wish to do so.
Pry the battery up with your metal spudger.
DO NOT PUNCTURE THE BATTERY
There are no strong adhesives, but there is tape holding the battery in.
BE CAREFUL
This may be a point of no return. Proceed at your own risk
Use your metal nudger, or any other tools that can help you, in order to remove the Qi Charger and Light Array
Be careful not to puncture the battery
Be careful not to cut the Light Array Ribbon Cable
Be careful not to cut the Qi Coil or its connecting wires
Grab a soldering iron. This is about to get even harder.
Use your favorite desoldering method to remove the battery from the circuit board.
BE CAREFUL NOT TO PUNCTURE THE BATTERY
DO NOT PUNCTURE THE BATTERY PROTECTIVE CIRCUIT
