Salta al contenuto principale
Introduzione
This is a quick, super simple replacement that can be done in the lot of the auto parts store. Good luck!
Strumenti
Nessun attrezzo specificato.
  1. Before you begin, make sure you have the right bulb.  I got this at the local autozone.
    • Before you begin, make sure you have the right bulb. I got this at the local autozone.
    • Do NOT touch the glass of the bulb. The oils from your fingers can drastically reduce the life of the bulb.
    • Vinyl or latex gloves are great if you have them available, but not required.
  2. Press firmly on the plugs clip and pull to remove the power cable from the bulb. Press firmly on the plugs clip and pull to remove the power cable from the bulb.
    • Press firmly on the plugs clip and pull to remove the power cable from the bulb.
  3. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  4. Lift up and remove the metal wire cage holding the bulb in place. Lift up and remove the metal wire cage holding the bulb in place. Lift up and remove the metal wire cage holding the bulb in place.
    • Lift up and remove the metal wire cage holding the bulb in place.
  5. Remove the bulb by pulling it away from the headlight enclosure.
    • Remove the bulb by pulling it away from the headlight enclosure.
    • Once the old bulb is removed, take your new one and place it in the headlight.
    • Follow the steps in reverse to secure the new bulb in the headlight.
Conclusione
To replace the bulb, follow the steps in reverse order.
Tim Asp
Membro da: 24/01/2011
1.297 Reputazione
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,933
