Salta al contenuto principale
Havoc Heli IR LED Replacement
Cosa ti serve
  1. Havoc Heli IR LED  Replacement, Havoc Heli IR LED: passo 1, immagine 1 di 2 Havoc Heli IR LED  Replacement, Havoc Heli IR LED: passo 1, immagine 2 di 2
    • Power off the controller before disassembly.
    • Place a small piece of tape over the Light button to prevent it from falling out in later steps.
    • Flip the controller over so the back is facing up.
  2. Havoc Heli IR LED  Replacement: passo 2, immagine 1 di 3 Havoc Heli IR LED  Replacement: passo 2, immagine 2 di 3 Havoc Heli IR LED  Replacement: passo 2, immagine 3 di 3
    • Remove the battery compartment screw with a small Phillips screw driver.
    • Lift off the battery cover.
    • Remove the six AA batteries from the compartment.
  3. Havoc Heli IR LED  Replacement: passo 3, immagine 1 di 3 Havoc Heli IR LED  Replacement: passo 3, immagine 2 di 3 Havoc Heli IR LED  Replacement: passo 3, immagine 3 di 3
    • Remove the remaining four screws with a small Phillips screw driver.
    • Flip the device over so the front is facing up.
    • Remove the front cover and place it to the left side.
    • Make sure to note the locations of the joysticks and other controls in case they fall out of place during this or future steps.
  4. Havoc Heli IR LED  Replacement: passo 4, immagine 1 di 1
    • Lift up the red IR LED cover to remove it.
  5. Havoc Heli IR LED  Replacement: passo 5, immagine 1 di 2 Havoc Heli IR LED  Replacement: passo 5, immagine 2 di 2
    • Use the soldering iron and solder wick to remove the solder from the IR LED you're replacing.
    • Pull the LED out through the top.
  6. Havoc Heli IR LED  Replacement: passo 6, immagine 1 di 2 Havoc Heli IR LED  Replacement: passo 6, immagine 2 di 2
    • Insert the new LED into the slot.
    • Make sure that the short lead of the LED is on the right.
    • Use the soldering iron and solder to connect the new LED.
Conclusione
Michael Kent
Membro da: 03/30/16
128 Reputazione
1 Guida realizzata
Michigan Tech, Team 1-13, Lauer Fall 2016 Membro di Michigan Tech, Team 1-13, Lauer Fall 2016
MTU-LAUER-F16S1G13
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 543
