Salta al contenuto principale
Hasee Z7M-i78172D1 Graphic Card Fan Replacement
Cosa ti serve
  1. Hasee Z7M-i78172D1 Graphic Card Fan Replacement, Rear Panel: passo 1, immagine 1 di 1
    • Use a #0 Phillips head screwdriver and unscrew the sixteen 7mm screws on the back of the device.
  2. Hasee Z7M-i78172D1 Graphic Card Fan Replacement: passo 2, immagine 1 di 3 Hasee Z7M-i78172D1 Graphic Card Fan Replacement: passo 2, immagine 2 di 3 Hasee Z7M-i78172D1 Graphic Card Fan Replacement: passo 2, immagine 3 di 3
    • Use a plastic opening tool to take off the back plastic panel.
  3. Hasee Z7M-i78172D1 Graphic Card Fan Replacement, Graphic Card Fan: passo 3, immagine 1 di 3 Hasee Z7M-i78172D1 Graphic Card Fan Replacement, Graphic Card Fan: passo 3, immagine 2 di 3 Hasee Z7M-i78172D1 Graphic Card Fan Replacement, Graphic Card Fan: passo 3, immagine 3 di 3
    • To take out the Graphics card fan it is necessary to disconnect the two Graphic card fan cables. Use a plastic opening tool to remove the cable.
  4. Hasee Z7M-i78172D1 Graphic Card Fan Replacement: passo 4, immagine 1 di 1
    • Use a #0 Phillips head screwdriver and unscrew the five 7mm screws holding the fan in place.
  5. Hasee Z7M-i78172D1 Graphic Card Fan Replacement: passo 5, immagine 1 di 2 Hasee Z7M-i78172D1 Graphic Card Fan Replacement: passo 5, immagine 2 di 2
    • Lift the Graphics card fan out and replace with the replacement fan.
Conclusione
Zachary Gay
Membro da: 02/14/18
124 Reputazione
1 Guida realizzata
USF Tampa, Team S6-G6, Eyestone Spring 2018 Membro di USF Tampa, Team S6-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S6G6
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 373
