Salta al contenuto principale
Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement
Cosa ti serve
  1. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: passo 1, immagine 1 di 3 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: passo 1, immagine 2 di 3 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: passo 1, immagine 3 di 3
    • Find the removable panel at the bottom of the hand.
    • Use your finger to push upwards and open the panel.
    • Slide the panel off and separate it from the hand.
  2. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: passo 2, immagine 1 di 2 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: passo 2, immagine 2 di 2
    • Remove the left-most battery by pushing down on the positive end and pulling it out.
    • Repeat this for the next two batteries.
  3. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, LED Lights: passo 3, immagine 1 di 1
    • Remove the screws within the gauntlet and surrounding the palm.
  4. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: passo 4, immagine 1 di 1
    • Open the gauntlet carefully, as there are wires connecting both sides.
    • Address which LED is faulty. Check if the wires connecting to it are all intact; If there is a detachment within the circuits, reconnect it to its location. The LED should operate in that instance.
  5. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: passo 5, immagine 1 di 1
    • To replace the LED chip, remove the screw holding the chip in place.
  6. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: passo 6, immagine 1 di 1
    • Ensure that the LED chip is in the correct area with the correct polarity.
    • Reconnect it to its respective surface and check if it fits with in the magnetic gem. If not, consider another replacement.
Conclusione
Jessica
Membro da: 02/24/23
109 Reputazione
1 Guida realizzata
Marist, Team 1-3, Chaterdon Spring 2023 Membro di Marist, Team 1-3, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G3
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 29
Tutti i Tempi: 222
