Salta al contenuto principale
Hasbro Bop-It Micro Series Speaker Replacement
Cosa ti serve
  1. Hasbro Bop-It Micro Series Speaker Replacement, Back Case: passo 1, immagine 1 di 1
    • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
  2. Hasbro Bop-It Micro Series Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
    • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. Hasbro Bop-It Micro Series Speaker Replacement: passo 3, immagine 1 di 1
    • Carefully separate the two sections, leaving them connected by the wires.
  4. Hasbro Bop-It Micro Series Speaker Replacement, Speaker: passo 4, immagine 1 di 2 Hasbro Bop-It Micro Series Speaker Replacement, Speaker: passo 4, immagine 2 di 2
    • Remove the (3) #3 Phillips head 6 mm screws using your Phillips #0 screwdriver, and remove the plastic with your fingers.
  5. Hasbro Bop-It Micro Series Speaker Replacement: passo 5, immagine 1 di 1
    • De-solder the speaker from the wires. Refer to the soldering guide for instructions on how to solder
Conclusione
Follow the steps of this guide in reverse to reassemble.
Altre 2 persone hanno completato questa guida.
Glenn Haag
Membro da: 09/29/16
479 Reputazione
3 Guide realizzate
IUPUI, Team 3-1, Harley Fall 2016 Membro di IUPUI, Team 3-1, Harley Fall 2016
IUPUI-HARLEY-F16S3G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,296
