Introduzione
If the game is turned on but the Bop-It button(s) does not work, this is because the button inside the device that provides functionality may be broken. To effectively replace them see this step-by-step guide.
Cosa ti serve
Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
Remove the buttons by de-soldering them from the wires they are attached to or from the mother board. Refer to the soldering guide here.
Altre 3 persone hanno completato questa guida.
