Salta al contenuto principale
Hasbro Bop-It Micro Series Buttons Replacement
Cosa ti serve
  1. Hasbro Bop-It Micro Series Buttons Replacement, Back Case: passo 1, immagine 1 di 1
    • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
  2. Hasbro Bop-It Micro Series Buttons Replacement: passo 2, immagine 1 di 1
    • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
    • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. Hasbro Bop-It Micro Series Buttons Replacement: passo 3, immagine 1 di 1
    • Carefully separate the two sections, leaving them connected by the wires.
  4. Hasbro Bop-It Micro Series Buttons Replacement, Buttons: passo 4, immagine 1 di 1
    • Remove the buttons by de-soldering them from the wires they are attached to or from the mother board. Refer to the soldering guide here.
  5. Hasbro Bop-It Micro Series Buttons Replacement: passo 5, immagine 1 di 1
    • After removing the buttons, solder new, operational buttons back into place.
Conclusione
Altre 3 persone hanno completato questa guida.
Glenn Haag
Membro da: 09/29/16
479 Reputazione
3 Guide realizzate
IUPUI, Team 3-1, Harley Fall 2016 Membro di IUPUI, Team 3-1, Harley Fall 2016
IUPUI-HARLEY-F16S3G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,928
