Salta al contenuto principale
Harrier Tablet by EE Disassembly
Cosa ti serve
  1. Harrier Tablet by EE Disassembly, opening the first layer: passo 1, immagine 1 di 3 Harrier Tablet by EE Disassembly, opening the first layer: passo 1, immagine 2 di 3 Harrier Tablet by EE Disassembly, opening the first layer: passo 1, immagine 3 di 3
    • Lay the tablet on a flat surface with the screen facing downward.
    • Use a guitar pick to pry up the rear most layer of the tablet, starting by the cover of the sim card.
    • Use a spudger to pry along the edges of the back layer of the tablet. Use the guitar picks to keep the edges propped open.
  2. Harrier Tablet by EE Disassembly, getting ready for the second layer: passo 2, immagine 1 di 2 Harrier Tablet by EE Disassembly, getting ready for the second layer: passo 2, immagine 2 di 2
    • Before opening the second layer, use a screwdriver to remove all the screws along the edges.
    • The top left screw has an anti-tamper seal on it. Damage to this seal will void any warranties of the tablet.
  3. Harrier Tablet by EE Disassembly, sort of disassemble entirely: passo 3, immagine 1 di 2 Harrier Tablet by EE Disassembly, sort of disassemble entirely: passo 3, immagine 2 di 2
    • Once the screws are removed, use a spudger and guitar picks to unclip the bezel.
    • Removing the battery and flexi rigid circuit board will likely cause damage. In order to disassemble further, you may also need to replace these parts.
    • To reassemble, first remove the sim card, then follow these instructions in reverse order.
    • Make sure the buttons are properly seated before snapping the first layer back on.
Conclusione
rarazzell
Membro da: 07/07/18
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 453
