Salta al contenuto principale
Introduzione
If your speakers are busted or faulty, this guide will help you in replacing one or both of the speakers in your Onyx Studio 2.
  1. Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device. Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device. Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
    Where can I find a new front panel for my speaker
    consomme69 - Replica
    If I take this off can I put it back on
    Burger King - Replica
  2. Remove the five 14.4 mm T10 Torx screws. Remove the five 14.4 mm T10 Torx screws.
    • Remove the five 14.4 mm T10 Torx screws.
    There are NO torxscrews. You have to pull out the rubber grille grips that are inside the screw holes FIRST, then use a regular sized Phillips head screwdriver to remove the cover. No Torxscrewdiver needed. I found this out after I had already purchased one from you guys.
    phillip columbus - Replica
  3. Gently pull the front apart from the back.
    • Gently pull the front apart from the back.
  4. Remove the four wires connecting the front and back panels. Pinch the connector tab and pull gently upwards.
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Pull the silicone button band off of the outer edge of the speaker.
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Disconnect the two pressure connections from the circuit board. Disconnect the two pressure connections from the circuit board.
    • Disconnect the two pressure connections from the circuit board.
  7. Gently remove the control board band by placing fingers in contact with it through the button openings. Work from the outer edges in so as not to bend the band.
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
    From where to buy Control panel
    ali - Replica
    From where to buy this control panel
    ali - Replica
  8. Disconnect the remaining connectors from the circuit board. Disconnect the Bluetooth antenna.
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Remove the four 10 mm T10 Torx screws. Pull the circuit board out of the device as it is now free.
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
  10. Using the metal spudger, gently pry off the two red and black connectors.
    • Using the metal spudger, gently pry off the two red and black connectors.
  11. Remove the four 14.3 mm T10 Torx screws. Remove the four 14.3 mm T10 Torx screws.
    • Remove the four 14.3 mm T10 Torx screws.
  12. Pull out the speaker, and if necessary follow these steps to replace the other identical speaker.
    • Pull out the speaker, and if necessary follow these steps to replace the other identical speaker.
    Please attach a link where best to buy parts/speakers for this model. I found your step by step instructions very well detailed except for the source of parts
    Bernard Rocha - Replica
Conclusione
Altre 6 persone hanno completato questa guida.
USF Tampa, Team 16-5, Blackwell Spring 2017 Membro di USF Tampa, Team 16-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G5
3 Membri
24 Guide realizzate
2 Commenti
Hi, do anyone know sparepart number for woofer elements?
Mikko Lehto - Replica
Hello.. what is the wattage of the speaker? and where can i get a replacement. how much?
James Santiago - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 143
Tutti i Tempi: 14,115
