Introduzione
If your speakers are busted or faulty, this guide will help you in replacing one or both of the speakers in your Onyx Studio 2.
Cosa ti serve
Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
Remove the five 14.4 mm T10 Torx screws.
There are NO torxscrews. You have to pull out the rubber grille grips that are inside the screw holes FIRST, then use a regular sized Phillips head screwdriver to remove the cover. No Torxscrewdiver needed. I found this out after I had already purchased one from you guys.
Mi bocina no tiene los 5 tornillos a la vista,tiene las cavidades ciegas, como lo abro???
Remove the four wires connecting the front and back panels.
Pinch the connector tab and pull gently upwards.
Repeat for the other three connectors.
Disconnect the remaining connectors from the circuit board.
Disconnect the Bluetooth antenna.
Remove the four 10 mm T10 Torx screws.
Pull the circuit board out of the device as it is now free.
Bisa di kirim
Bisa pesan 1
I own two of these and the both shut down on their own.. where do I buy the replacement boards from?
Using the metal spudger, gently pry off the two red and black connectors.
Pull out the speaker, and if necessary follow these steps to replace the other identical speaker.
Please attach a link where best to buy parts/speakers for this model. I found your step by step instructions very well detailed except for the source of parts
Altre 7 persone hanno completato questa guida.
2 Commenti
Hi, do anyone know sparepart number for woofer elements?
Hello.. what is the wattage of the speaker? and where can i get a replacement. how much?
Where can I find a new front panel for my speaker
consomme69 - Replica
If I take this off can I put it back on
Burger King - Replica
