Salta al contenuto principale
Harman Kardon Onyx Studio 2 Front Panel Replacement
Cosa ti serve
  1. Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: passo 1, immagine 1 di 3 Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: passo 1, immagine 2 di 3 Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: passo 1, immagine 3 di 3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Front Panel Replacement: passo 2, immagine 1 di 2 Harman Kardon Onyx Studio 2 Front Panel Replacement: passo 2, immagine 2 di 2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Front Panel Replacement: passo 3, immagine 1 di 1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Front Panel Replacement: passo 4, immagine 1 di 2 Harman Kardon Onyx Studio 2 Front Panel Replacement: passo 4, immagine 2 di 2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
Conclusione
To reassemble, follow these steps in reverse order.
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 16-5, Blackwell Spring 2017 Membro di USF Tampa, Team 16-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G5
3 Membri
24 Guide realizzate
Un commento
Hi, I have the ONYX STUDIO with the silver ring that serves as the stand and the handle at the same time. After removing the front grill, I find the same five holes as it is shown on your pics but there are no screws. I can just see a bottom made of plastic. Do you have experience with that? Is that just some cover I can get thru using a screwdriver and I find the screws beneath?
I want to look inside as I am facing the problem with not working battery. As soon as I unplug the power source, it stops working.
Thank you for your comments.
Vaclav Matoulek - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 41
Tutti i Tempi: 6,034
