Salta al contenuto principale
Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement
Cosa ti serve
  1. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Front Panel: passo 1, immagine 1 di 3 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Front Panel: passo 1, immagine 2 di 3 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Front Panel: passo 1, immagine 3 di 3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: passo 2, immagine 1 di 2 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: passo 2, immagine 2 di 2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: passo 3, immagine 1 di 1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: passo 4, immagine 1 di 2 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: passo 4, immagine 2 di 2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Control Board: passo 5, immagine 1 di 1
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: passo 6, immagine 1 di 2 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: passo 6, immagine 2 di 2
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: passo 7, immagine 1 di 2 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: passo 7, immagine 2 di 2
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
  8. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Circuit Board: passo 8, immagine 1 di 2 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Circuit Board: passo 8, immagine 2 di 2
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: passo 9, immagine 1 di 2 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: passo 9, immagine 2 di 2
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
  10. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Bluetooth Antenna: passo 10, immagine 1 di 2 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Bluetooth Antenna: passo 10, immagine 2 di 2
    • Using the wide blue plastic opening tool, gently peel back edges of the Bluetooth board.
    • Peel off completely and remove from the device.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 16-5, Blackwell Spring 2017 Membro di USF Tampa, Team 16-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G5
3 Membri
24 Guide realizzate
Un commento
Any idea where we can purchase the replacement parts?
Cort Krause - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 9,458
