Salta al contenuto principale
Introduzione
This guide will help you replace the Harman Kardon Esquire Mini speakers. In case the speakers are not working or there is a buzzing sound and you need to replace it, this guide will help you to do so. A plastic opening tool and PH0 screwdriver will be needed to accomplish this guide.
Parti
Nessuna parte specificata.
  1. Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
  3. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  4. Pull out the motherboard by removing 4 screws around the perimeter of the motherboard. Keep in mind the wires still attached to the speakers, so pull gently.
    • Pull out the motherboard by removing 4 screws around the perimeter of the motherboard. Keep in mind the wires still attached to the speakers, so pull gently.
  5. Using the PH0 screwdriver unscrew the screws, there is one 4 mm screw on each speaker.
    • Using the PH0 screwdriver unscrew the screws, there is one 4 mm screw on each speaker.
    • Re-do the same steps above for the other speaker to remove it.
  6. Remove the speaker by using the plastic opening tool. Apply a gentle upward force to remove it.
    • Remove the speaker by using the plastic opening tool. Apply a gentle upward force to remove it.
Conclusione
Altre 3 persone hanno completato questa guida.
yousef aljeemaz
Membro da: 18/10/2017
636 Reputazione
5 Guide realizzate
USF Tampa, Team S1-G9, Cagle Fall 2017 Membro di USF Tampa, Team S1-G9, Cagle Fall 2017
USFT-CAGLE-F17S1G9
5 Membri
5 Guide realizzate
Where can i buy a new speaker for this sound box ? thanks… sizinojr@gmail.com
Sizino Santos - Replica
Did you ever find the replacement speaker? I need one too.
Thx.
Troy -
Thanks, I need speaker also, where can I buy.
mnyucel@yahoo.com
mnyucel - Replica
Hi, I also need to know where could get new replacement speaker.
Thanks
mezafernando23 -
Hi, I also need to know where could I get the replacement speaker.
Thanks
mezafernando23 -
What model of speaker for this sound box? Thank you.
Gustavo Campos Freitas - Replica
Hi, I also need to know where could I get the  new replacement
many thanks, [mailto:joenora2007@gmail.com|joenora2007@gmail.com]
Joe Hsieh - Replica
Mine blew out, and my friends blew out too. wtf?
Not impressed with the quality.
Ronald Man - Replica
So many people trying to fix this sh** !
I just opened mine, it looks like one side overheated and melt the plastic around the speaker.
I can’t find any replacement speaker anywhere on internet.
HK sucks ! Last time I buy anything from them.
Alfred Murbin - Replica
Useless post as it doesn’t have proper answers
ruslan tzyanov - Replica
I also need a speaker. But do not now what analogs or generics may suit.
Ya sounds like we are all having this issue sad this speaker seems to have the same issue.Anyone mention where to find the replacement speaker
Chad Galbasini - Replica
Hello;
please Where can i buy the speaker replacement????
varovarovaro@gmail.com
thanks!
AA OO - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 225
Tutti i Tempi: 3,866
