Introduzione
This guide will help you replace the Harman Kardon Esquire Mini speakers. In case the speakers are not working or there is a buzzing sound and you need to replace it, this guide will help you to do so. A plastic opening tool and PH0 screwdriver will be needed to accomplish this guide.
Cosa ti serve
Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
Pull out the motherboard by removing 4 screws around the perimeter of the motherboard. Keep in mind the wires still attached to the speakers, so pull gently.
Altre 15 persone hanno completato questa guida.
39 Commenti
Where can i buy a new speaker for this sound box ? thanks… sizinojr@gmail.com
Did you ever find the replacement speaker? I need one too.
Thx.
Troy -
Hi, I also need to know where could get new replacement speaker.
Thanks
Hi, I also need to know where could I get the replacement speaker.
Thanks
