Introduzione
This guide will show you how to remove the old brake pads, and then install the new ones.
Strumenti
Ricambi
Nessuna parte specificata.
For the best access to the brake pads, we recommend securing the motorcycle in an upright position.
If you do not have a motorcycle lift, you will still be able change the brake pads, but it is still a good idea to secure the front wheel in place.
Using a 1/4" hex head or allen wrench, unscrew the two bolts holding the front brake assembly to the fork.
Unscrew and remove the bottom bolt, but do not completely remove the top bolt yet.
Using a Phillips #2 screwdriver, remove the two screws securing the cover on the master brake-fluid reservoir.
Carefully remove the cover of the master reservoir, making sure that you do not spill any of the brake fluid.
Position the screw of a large C clamp so that the head of the screw is pressing against the inside of the brake piston.
It is possible to use your hands rather than a C clamp, but it is much more difficult.
Slowly tighten the C clamp, forcing the brake piston back into the brake cylinder until it is completely depressed.
