Salta al contenuto principale
Hannspree SN12E2 RAM Replacement
Cosa ti serve
  1. Hannspree SN12E2 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 RAM Replacement: passo 2, immagine 1 di 1
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 RAM Replacement: passo 3, immagine 1 di 3 Hannspree SN12E2 RAM Replacement: passo 3, immagine 2 di 3 Hannspree SN12E2 RAM Replacement: passo 3, immagine 3 di 3
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 RAM Replacement, RAM: passo 4, immagine 1 di 2 Hannspree SN12E2 RAM Replacement, RAM: passo 4, immagine 2 di 2
    • Remove the RAM access door.
    • Remove the two 3mm screws using a Phillips #0 screwdriver.
    • Gently lift on the door out of place.
    • When replacing the door it should click into place. Ensure the alignment tabs are correctly seated and gently push until it clicks into place.
  5. Hannspree SN12E2 RAM Replacement: passo 5, immagine 1 di 3 Hannspree SN12E2 RAM Replacement: passo 5, immagine 2 di 3 Hannspree SN12E2 RAM Replacement: passo 5, immagine 3 di 3
    • Gently push outward on the two retaining clips, being careful not to damage the motherboard.
    • Lift up on the RAM until it makes a 35 degree angle with the board.
    • Remove the RAM by pulling away from the housing at 35 degrees.
Conclusione
Tim Chase
Membro da: 03/25/19
363 Reputazione
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 421
