Introduzione
We will gain access to the screen, enabling us to replace it with a new screen.
  1. Place Visor Edge face down.
    • Place Visor Edge face down.
    • Notice the tab connecting the flip cover to the back of the PDA.
    • Gently push tab forward.
    • Do not pull on the flip cover to try and remove it from the PDA.
  2. Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
    • Remove the black plate from the PDA.
    • Remove four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the remaining 3.9 mm Philips screw holding together the stylus holster and the frame.
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
    • Remove the white frame from the PDA.
    • The frame may get stuck on the corners so be very gentle when working the corners off.
    • Pull front cover off gently.
    • With the device flipped over, use the tweezers to remove the ribbon cable attaching the screen to the circuit board.
    • Wedge the spudger in between the glass and the metal frame.
    • Slide the spudger down the length of the screen to detach from the frame.
    • With your hands, pry the screen up from the detached side, and the screen will pop off.
Conclusione
Cal Poly, Team 11-28, Maness Winter 2011 Membro di Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 Membri
7 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,273
