Introduzione
This guide is used to replace the motor.
Cosa ti serve
Passo 1 Base Removal
Attenzione: i passaggi 1-5 provengono da una guida contrassegnata come in corso.
Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
Remove to electrical cap to the positive terminal(black terminal), and undo the wiring.
Altre 2 persone hanno completato questa guida.
