Salta al contenuto principale
Hamilton Beach 70730 Drive Shaft Replacement
Cosa ti serve
  1. Hamilton Beach 70730 Drive Shaft Replacement, Bowl: passo 1, immagine 1 di 1
    • Unscrew the cover by turning it counterclockwise.
  2. Hamilton Beach 70730 Drive Shaft Replacement: passo 2, immagine 1 di 1
    • Grab the scraper by the midsection to remove.
  3. Hamilton Beach 70730 Drive Shaft Replacement: passo 3, immagine 1 di 1
    • Carefully remove the blades by lifting them off of the blade shaft.
  4. Hamilton Beach 70730 Drive Shaft Replacement: passo 4, immagine 1 di 1
    • Rotate the bowl counterclockwise to release it from the base.
  5. Hamilton Beach 70730 Drive Shaft Replacement: passo 5, immagine 1 di 1
    • Make sure there is no food or grime along the outside of the bowl or the base.
  6. Hamilton Beach 70730 Drive Shaft Replacement, Drive Shaft: passo 6, immagine 1 di 1
    • Using the metal spudger, remove the four adhesive plastic covers that hide the screws.
    • These covers are adhered to the screws.
  7. Hamilton Beach 70730 Drive Shaft Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove any excess glue that is adhered to the screws with the precision tweezers.
  8. Hamilton Beach 70730 Drive Shaft Replacement: passo 8, immagine 1 di 1
    • Using a JIS #1 driver, remove the four 10 mm screws.
  9. Hamilton Beach 70730 Drive Shaft Replacement: passo 9, immagine 1 di 1
    • Lift the driveshaft off of the base.
Conclusione
Mack Bernard
Membro da: 03/08/16
597 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 31
Tutti i Tempi: 996
