Salta al contenuto principale
Hamilton Beach 64650 Mixer Release Button Replacement
Cosa ti serve
  1. Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: passo 1, immagine 1 di 3 Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: passo 1, immagine 2 di 3 Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: passo 1, immagine 3 di 3
    • Depress mixer release button fully and lift mixer off of the platform.
    • Remove the bowl from the stand.
  2. Hamilton Beach 64650 Mixer Release Button Replacement: passo 2, immagine 1 di 3 Hamilton Beach 64650 Mixer Release Button Replacement: passo 2, immagine 2 di 3 Hamilton Beach 64650 Mixer Release Button Replacement: passo 2, immagine 3 di 3
    • Remove and set aside the three 1.3 mm Philips #2 screws holding the plastic cover in place.
  3. Hamilton Beach 64650 Mixer Release Button Replacement: passo 3, immagine 1 di 2 Hamilton Beach 64650 Mixer Release Button Replacement: passo 3, immagine 2 di 2
    • Shift the cover to allow the plastic retaining hook to fit through the hole easily.
    • Lift the cover away.
  4. Hamilton Beach 64650 Mixer Release Button Replacement: passo 4, immagine 1 di 3 Hamilton Beach 64650 Mixer Release Button Replacement: passo 4, immagine 2 di 3 Hamilton Beach 64650 Mixer Release Button Replacement: passo 4, immagine 3 di 3
    • Fully depress the mixer release button, pushing it through the mounting hole.
    • Push the button slightly upwards once it is inside the stand to access the spring underneath it.
    • Carefully remove the button from the stand while leaving spring in place.
  5. Hamilton Beach 64650 Mixer Release Button Replacement: passo 5, immagine 1 di 3 Hamilton Beach 64650 Mixer Release Button Replacement: passo 5, immagine 2 di 3 Hamilton Beach 64650 Mixer Release Button Replacement: passo 5, immagine 3 di 3
    • Depress the spring slightly and lift upward to remove.
    • Replace with a new spring to have a working button again.
Conclusione
Gwen Davis
Membro da: 03/24/16
519 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,111
