Salta al contenuto principale
Hamilton Beach 51101BA Rotor Replacement
Cosa ti serve
  1. Hamilton Beach 51101BA Rotor Replacement, Rotor: passo 1, immagine 1 di 3 Hamilton Beach 51101BA Rotor Replacement, Rotor: passo 1, immagine 2 di 3 Hamilton Beach 51101BA Rotor Replacement, Rotor: passo 1, immagine 3 di 3
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Rotor Replacement: passo 2, immagine 1 di 1
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Rotor Replacement: passo 3, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
  4. Hamilton Beach 51101BA Rotor Replacement: passo 4, immagine 1 di 1
    • Unhinge the plastic motor platform from the blender.
    • You may need a plastic spudger to unhinge the motor platform from the blender.
  5. Hamilton Beach 51101BA Rotor Replacement: passo 5, immagine 1 di 2 Hamilton Beach 51101BA Rotor Replacement: passo 5, immagine 2 di 2
    • Using a spudger, carefully insert the tip into the coil of wire around motor.
    • This is used to hold the rotating piece of the motor still.
  6. Hamilton Beach 51101BA Rotor Replacement: passo 6, immagine 1 di 1
    • Remove the white rotor piece by rotating it counter-clockwise.
    • While rotating, make sure the rotating piece of the motor remains still.
Conclusione
Andrew Huff
Membro da: 09/04/15
568 Reputazione
3 Guide realizzate
USF Tampa, Team 2-5, Sullivan Fall 2015 Membro di USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Membri
5 Guide realizzate
Un commento
Hi, Any idea where to get a new rotor.
Allen Reed - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 30
Tutti i Tempi: 1,244
