Salta al contenuto principale
Hamilton Beach 51101BA Power Cord Replacement
Cosa ti serve
  1. Hamilton Beach 51101BA Power Cord Replacement, Power Cord: passo 1, immagine 1 di 3 Hamilton Beach 51101BA Power Cord Replacement, Power Cord: passo 1, immagine 2 di 3 Hamilton Beach 51101BA Power Cord Replacement, Power Cord: passo 1, immagine 3 di 3
    • Remove container from base.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Power Cord Replacement: passo 2, immagine 1 di 1
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Power Cord Replacement: passo 3, immagine 1 di 1
    • Lift the two wires from the motor platform.
  4. Hamilton Beach 51101BA Power Cord Replacement: passo 4, immagine 1 di 1
    • Using the wire cutters, cut the end of the thick black wires.
Conclusione
To reassemble your device, you must solder the new power cord to the thin black and thin gray wires, and follow the steps in reverse order. Requires soldering skills.
Andrew Huff
Membro da: 09/04/15
568 Reputazione
3 Guide realizzate
USF Tampa, Team 2-5, Sullivan Fall 2015 Membro di USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,942
