Salta al contenuto principale
Hamilton Beach 51101BA Power Button Replacement
Cosa ti serve
  1. Hamilton Beach 51101BA Power Button Replacement, Power Button: passo 1, immagine 1 di 3 Hamilton Beach 51101BA Power Button Replacement, Power Button: passo 1, immagine 2 di 3 Hamilton Beach 51101BA Power Button Replacement, Power Button: passo 1, immagine 3 di 3
    • Remove the container from the base.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Power Button Replacement: passo 2, immagine 1 di 1
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Power Button Replacement: passo 3, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
  4. Hamilton Beach 51101BA Power Button Replacement: passo 4, immagine 1 di 2 Hamilton Beach 51101BA Power Button Replacement: passo 4, immagine 2 di 2
    • Unhinge the motor platform from the blender.
    • You may need a plastic spudger to unhinge the plastic bottom piece from the base of the blender.
    • You do not need to completely remove this piece from the base.
  5. Hamilton Beach 51101BA Power Button Replacement: passo 5, immagine 1 di 1
    • Pull out the rectangular green piece.
    • This is the actual power button.
  6. Hamilton Beach 51101BA Power Button Replacement: passo 6, immagine 1 di 1
    • Some experience in soldering is required!
    • On the back of the power button, desolder the red and grey wires that are connected to the piece.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 2-5, Sullivan Fall 2015 Membro di USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 29
Tutti i Tempi: 3,266
