Salta al contenuto principale
Hamilton Beach 51101BA Motor Replacement
Cosa ti serve
  1. Hamilton Beach 51101BA Motor Replacement, Rotor: passo 1, immagine 1 di 3 Hamilton Beach 51101BA Motor Replacement, Rotor: passo 1, immagine 2 di 3 Hamilton Beach 51101BA Motor Replacement, Rotor: passo 1, immagine 3 di 3
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Motor Replacement: passo 2, immagine 1 di 1
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Motor Replacement: passo 3, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
  4. Hamilton Beach 51101BA Motor Replacement: passo 4, immagine 1 di 1
    • Unhinge the plastic motor platform from the blender.
    • You may need a plastic spudger to unhinge the motor platform from the blender.
  5. Hamilton Beach 51101BA Motor Replacement: passo 5, immagine 1 di 2 Hamilton Beach 51101BA Motor Replacement: passo 5, immagine 2 di 2
    • Using a spudger, carefully insert the tip into the coil of wire around motor.
    • This is used to hold the rotating piece of the motor still.
  6. Hamilton Beach 51101BA Motor Replacement: passo 6, immagine 1 di 1
    • Remove the white rotor piece by rotating it counter-clockwise.
    • While rotating, make sure the rotating piece of the motor remains still.
  7. Hamilton Beach 51101BA Motor Replacement, Motor: passo 7, immagine 1 di 2 Hamilton Beach 51101BA Motor Replacement, Motor: passo 7, immagine 2 di 2
    • Move the motor platform to the side.
    • Lift up the motor and remove it from the blender.
  8. Hamilton Beach 51101BA Motor Replacement: passo 8, immagine 1 di 1
    • Some soldering experience required!
    • Desolder the red wire from the green plastic piece.
  9. Hamilton Beach 51101BA Motor Replacement: passo 9, immagine 1 di 1
    • Cut the thin black wire from the wire cap.
Conclusione
Andrew Huff
Membro da: 09/04/15
568 Reputazione
3 Guide realizzate
USF Tampa, Team 2-5, Sullivan Fall 2015 Membro di USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Membri
5 Guide realizzate
2 Commenti
This article appears to be unfinished. You cut 2 wires at the end... then what? Reconnecting them doesn't make any sense.
Geo Jack Jack - Replica
Que tipo de motor tengo que comprar?
hugoalex521 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 72
Tutti i Tempi: 7,022
