Salta al contenuto principale
Hamilton Beach 51101BA Blades Replacement
Cosa ti serve
  1. Hamilton Beach 51101BA Blades Replacement, Blades: passo 1, immagine 1 di 1
    • Remove the lid from the container by holding the base and pulling up on the lid.
  2. Hamilton Beach 51101BA Blades Replacement: passo 2, immagine 1 di 3 Hamilton Beach 51101BA Blades Replacement: passo 2, immagine 2 di 3 Hamilton Beach 51101BA Blades Replacement: passo 2, immagine 3 di 3
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  3. Hamilton Beach 51101BA Blades Replacement: passo 3, immagine 1 di 3 Hamilton Beach 51101BA Blades Replacement: passo 3, immagine 2 di 3 Hamilton Beach 51101BA Blades Replacement: passo 3, immagine 3 di 3
    • Avoid placing your fingers on the blade, as they could be sharp.
    • Using a pair of pliers to hold the blade in place, use your other hand to unscrew the rubber piece on the bottom of the container.
    • Remove the rubber piece and the two washers by rotating the rubber piece counter-clockwise.
  4. Hamilton Beach 51101BA Blades Replacement: passo 4, immagine 1 di 1
    • Carefully, pull the blades out of the container as they are very sharp.
    • Using the pliers, remove blades and the washer around the blade shaft.
Conclusione
To reassemble your device with the new blade assembly, follow these instructions in reverse order.
Altre 6 persone hanno completato questa guida.
USF Tampa, Team 2-5, Sullivan Fall 2015 Membro di USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Membri
5 Guide realizzate
3 Commenti
Need to know how to install parts and how many
papi3701@aol.com - Replica
Looks like I missed parts need to know the order son cuantaty
For my 501101B blender, the whole blade assembly popped out, so the blended smoothie draws at the bottom like a water falls How to fix this?
Joyful Joy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 108
Tutti i Tempi: 11,548
