Introduzione
This is a straight-forward process that requires removal of a few screws and two wire caps.
Cosa ti serve
Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
To reassemble your device, follow these instructions in reverse order. Make sure to correctly replace the wires using tape you placed earlier as a reference.
Altre 2 persone hanno completato questa guida.
