Salta al contenuto principale
Hamilton Beach 25460Z Plug Wiring Replacement
Cosa ti serve
  1. Hamilton Beach 25460Z Plug Wiring Replacement, Plug Wiring: passo 1, immagine 1 di 2 Hamilton Beach 25460Z Plug Wiring Replacement, Plug Wiring: passo 1, immagine 2 di 2
    • Unplug your device before proceeding with disassembly.
    • Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
  2. Hamilton Beach 25460Z Plug Wiring Replacement: passo 2, immagine 1 di 1
    • Lift up the plastic cover to expose the plug wiring.
    • Mark the plug wire connected to the red wire with a piece of tape. This will be used as a reference for reassembly.
  3. Hamilton Beach 25460Z Plug Wiring Replacement: passo 3, immagine 1 di 3 Hamilton Beach 25460Z Plug Wiring Replacement: passo 3, immagine 2 di 3 Hamilton Beach 25460Z Plug Wiring Replacement: passo 3, immagine 3 di 3
    • Use the pliers to pinch the widest point of the cap. This should be done opposite of the already existing crimps.
    • Slide off the white cap.
    • Repeat these steps for the second white cap.
  4. Hamilton Beach 25460Z Plug Wiring Replacement: passo 4, immagine 1 di 2 Hamilton Beach 25460Z Plug Wiring Replacement: passo 4, immagine 2 di 2
    • Remove the two rubber screw covers from the bottom of the Panini Press.
    • Remove the four uncovered 10mm screws with the PH2 Screwdriver.
  5. Hamilton Beach 25460Z Plug Wiring Replacement: passo 5, immagine 1 di 2 Hamilton Beach 25460Z Plug Wiring Replacement: passo 5, immagine 2 di 2
    • Lift the plastic lower heating element up and place to the side for reassembly. You have now disconnected the plug wiring completely.
Conclusione
To reassemble your device, follow these instructions in reverse order. Make sure to correctly replace the wires using tape you placed earlier as a reference.
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 6-27, Amido Winter 2015 Membro di Cal Poly, Team 6-27, Amido Winter 2015
CPSU-AMIDO-W15S6G27
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 670
