Salta al contenuto principale
Hair Dryer Electrical Brushes Replacement
Cosa ti serve
  1. Hair Dryer Electrical Brushes Replacement, Electrical Brushes: passo 1, immagine 1 di 3 Hair Dryer Electrical Brushes Replacement, Electrical Brushes: passo 1, immagine 2 di 3 Hair Dryer Electrical Brushes Replacement, Electrical Brushes: passo 1, immagine 3 di 3
    • Make sure to unplug the device before beginning.
    • Rotate the stainless steel filter counterclockwise and pull upwards to remove it.
  2. Hair Dryer Electrical Brushes Replacement: passo 2, immagine 1 di 2 Hair Dryer Electrical Brushes Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the two screws securing the back cover.
  3. Hair Dryer Electrical Brushes Replacement: passo 3, immagine 1 di 3 Hair Dryer Electrical Brushes Replacement: passo 3, immagine 2 di 3 Hair Dryer Electrical Brushes Replacement: passo 3, immagine 3 di 3
    • Lift off the back cover.
  4. Hair Dryer Electrical Brushes Replacement: passo 4, immagine 1 di 3 Hair Dryer Electrical Brushes Replacement: passo 4, immagine 2 di 3 Hair Dryer Electrical Brushes Replacement: passo 4, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the two screws securing the dryer motor.
    • Remove the motor from its plastic housing.
  5. Hair Dryer Electrical Brushes Replacement: passo 5, immagine 1 di 3 Hair Dryer Electrical Brushes Replacement: passo 5, immagine 2 di 3 Hair Dryer Electrical Brushes Replacement: passo 5, immagine 3 di 3
    • Unscrew the small plastic cap on the side of the motor and lift out the spring.
    • Remove the carbon electrical brush.
    • Repeat for the cap on the other side of the motor.
  6. Hair Dryer Electrical Brushes Replacement: passo 6, immagine 1 di 3 Hair Dryer Electrical Brushes Replacement: passo 6, immagine 2 di 3 Hair Dryer Electrical Brushes Replacement: passo 6, immagine 3 di 3
    • Install the new carbon brushes, and screw the caps back on.
    • Make sure the spring beneath the cap is properly positioned before tightening,
  7. Hair Dryer Electrical Brushes Replacement: passo 7, immagine 1 di 3 Hair Dryer Electrical Brushes Replacement: passo 7, immagine 2 di 3 Hair Dryer Electrical Brushes Replacement: passo 7, immagine 3 di 3
    • Place the motor back into the housing.
    • Rotate the motor clockwise to screw it into place.
    • Refasten the two motor screws using a Phillips #1 screwdriver.
  8. Hair Dryer Electrical Brushes Replacement: passo 8, immagine 1 di 3 Hair Dryer Electrical Brushes Replacement: passo 8, immagine 2 di 3 Hair Dryer Electrical Brushes Replacement: passo 8, immagine 3 di 3
    • Place the white wires coming off the motor back in the slots.
    • Place the diode in the slots.
  9. Hair Dryer Electrical Brushes Replacement: passo 9, immagine 1 di 2 Hair Dryer Electrical Brushes Replacement: passo 9, immagine 2 di 2
    • Set the power cord back in its slot.
  10. Hair Dryer Electrical Brushes Replacement: passo 10, immagine 1 di 3 Hair Dryer Electrical Brushes Replacement: passo 10, immagine 2 di 3 Hair Dryer Electrical Brushes Replacement: passo 10, immagine 3 di 3
    • Reinstall the back cover.
  11. Hair Dryer Electrical Brushes Replacement: passo 11, immagine 1 di 3 Hair Dryer Electrical Brushes Replacement: passo 11, immagine 2 di 3 Hair Dryer Electrical Brushes Replacement: passo 11, immagine 3 di 3
    • Place the two screws back in place and tighten them with a Phillips #1 screwdriver.
Conclusione
Enjoy your functional hair dryer!
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 74
Tutti i Tempi: 1,455
