Introduzione
The battery should be inspected if the phone is constantly overheating and powering off.
  1. Turn off your cell phone before disassembling.
    • Turn off your cell phone before disassembling.
  2. Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. Use the Sim card ejection tool to remove both the sim card trays. Use the Sim card ejection tool to remove both the sim card trays.
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  6. Pry off the back with a plastic opening tool. Pry off the back with a plastic opening tool.
    • Pry off the back with a plastic opening tool.
  7. Remove the pink sticker.
    • Remove the pink sticker.
  8. Remove the three 1.5mm Phillips #000 screws.
    • Remove the three 1.5mm Phillips #000 screws.
  9. Use a plastic opening tool to disconnect the orange and black battery cables from the motherboard. Use a plastic opening tool to disconnect the orange and black battery cables from the motherboard.
    • Use a plastic opening tool to disconnect the orange and black battery cables from the motherboard.
  10. Remove the battery from the phone.
    • Remove the battery from the phone.
Conclusione
Altre 4 persone hanno completato questa guida.
Klara Asllani
Membro da: 25/01/2018
713 Reputazione
5 Guide realizzate
USF Tampa, Team S7-G6, Passmore Spring 2018 Membro di USF Tampa, Team S7-G6, Passmore Spring 2018
USFT-PASSMORE-S18S7G6
3 Membri
6 Guide realizzate
Just did this successfully, thanks for the steps.
I’d suggest adding to BE CAREFUL WHEN PRYING OUT THE BATTERY. #1 there is the screen cable under there and if you damage that, then have fun getting a new screen. #2 lithium batteries can ignite when punctured (like I did). Go easy working your way in and take note of where the screen cable is (lower black cable in step 9 image).
russellvinegar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 112
Tutti i Tempi: 1,297
