Introduzione
This guide demonstrates the procedure for replacing a faulty camera in the HTC myTouch 3G.
Press each thumb on both sides of the upper corners and apply pressure downwards.
Then, while still applying pressure, slide the back cover down.
Turn the piece housing the circuit boards over to the side with the mounted camera.
Remove the three 3-mm Phillips head screws located on the top circuit board.
