Introduzione
Takes you through the steps to install the vibrator.
Cosa ti serve
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Attrezzo utilizzato in questo passaggio:Spudger$3.99
Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
Attrezzo utilizzato in questo passaggio:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use the tweezers to remove the vibrator module.
Conclusione
