Introduzione
Takes you through the steps to install the speakers.
Parti
Nessuna parte specificata.
Remove the back case with your fingernail to expose the battery. (Not shown in picture)
Pull the black tab to remove the battery.
Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
Use a T5 Torx screwdriver to remove four 6mm screws that secure the back panel to the main body.
Quasi finito!
Conclusione
