Introduzione
This guide takes you through the steps to install the front panel buttons.
Cosa ti serve
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Attrezzo utilizzato in questo passaggio:Spudger$3.99
Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
Attrezzo utilizzato in questo passaggio:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Use the spudger to pry the camera off.
Remove the four 5mm screws with the T5 Torx screwdriver.
Remove the keyboard slider from the main body.
Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
