Salta al contenuto principale
HTC Wizard 100 Speakers Replacement
Cosa ti serve
  1. HTC Wizard 100 Speakers Replacement, Battery: passo 1, immagine 1 di 2 HTC Wizard 100 Speakers Replacement, Battery: passo 1, immagine 2 di 2
    • Power the phone off.
    • Use your thumb to gently press downward and away from the camera to remove the battery cover.
  2. HTC Wizard 100 Speakers Replacement: passo 2, immagine 1 di 2 HTC Wizard 100 Speakers Replacement: passo 2, immagine 2 di 2
    • Pull on the plastic tab to release the battery.
  3. HTC Wizard 100 Speakers Replacement, Back Case: passo 3, immagine 1 di 2 HTC Wizard 100 Speakers Replacement, Back Case: passo 3, immagine 2 di 2
    • Use a plastic opening tool to remove the camera cover.
    • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Lift the camera cover off of the phone.
  4. HTC Wizard 100 Speakers Replacement: passo 4, immagine 1 di 1
    • Remove the stylus from the phone.
    • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
    • One of the screws might be under a sticker, which will void your warranty.
  5. HTC Wizard 100 Speakers Replacement: passo 5, immagine 1 di 3 HTC Wizard 100 Speakers Replacement: passo 5, immagine 2 di 3 HTC Wizard 100 Speakers Replacement: passo 5, immagine 3 di 3
    • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
    • If your phone contains a memory card, you may want to remove it before proceeding with this step.
    • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Lift the back case off completely.
    • The speakers might be dangling and unsecured.
  6. HTC Wizard 100 Speakers Replacement, Speakers: passo 6, immagine 1 di 2 HTC Wizard 100 Speakers Replacement, Speakers: passo 6, immagine 2 di 2
    • Grip the speaker connector with your thumb and finger and gently pull up.
    • Repeat for 2nd speaker.
Conclusione
Taylor Stone
Membro da: 10/06/11
45 Reputazione
2 Guide realizzate
Cal Poly, Team 20-28, Maness Fall 2011 Membro di Cal Poly, Team 20-28, Maness Fall 2011
CPSU-MANESS-F11S20G28
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 7
Tutti i Tempi: 591
