Salta al contenuto principale
HTC Windows Phone 8S Logic Board Replacement
Cosa ti serve
Panoramica Video
  1. HTC Windows Phone 8S Logic Board Replacement, Loudspeaker: passo 1, immagine 1 di 3 HTC Windows Phone 8S Logic Board Replacement, Loudspeaker: passo 1, immagine 2 di 3 HTC Windows Phone 8S Logic Board Replacement, Loudspeaker: passo 1, immagine 3 di 3
    • Switch off the phone.
    • Remove the SIM / memory card cover.
    • Remove any SIM and memory cards.
    • Use screwdriver torx T5 and unscrew the two screws at the bottom of the battery / back cover.
  2. HTC Windows Phone 8S Logic Board Replacement: passo 2, immagine 1 di 3 HTC Windows Phone 8S Logic Board Replacement: passo 2, immagine 2 di 3 HTC Windows Phone 8S Logic Board Replacement: passo 2, immagine 3 di 3
    • Use a plastic tool and slowly separate the back cover.
    • The loudspeaker is inside on the back cover.
  3. HTC Windows Phone 8S Logic Board Replacement, Battery: passo 3, immagine 1 di 3 HTC Windows Phone 8S Logic Board Replacement, Battery: passo 3, immagine 2 di 3 HTC Windows Phone 8S Logic Board Replacement, Battery: passo 3, immagine 3 di 3
    • Use a Phillips #0 screwdriver and remove the 4x silver screws.
    • With a plastic tool carefully separate the battery from the logic board.
  4. HTC Windows Phone 8S Logic Board Replacement: passo 4, immagine 1 di 3 HTC Windows Phone 8S Logic Board Replacement: passo 4, immagine 2 di 3 HTC Windows Phone 8S Logic Board Replacement: passo 4, immagine 3 di 3
    • The battery connector is under the middle frame. Remove it and disconnect the battery.
    • Model: BM59100 / 3,8VDC / 1700mAh
  5. HTC Windows Phone 8S Logic Board Replacement, Flex Cables: passo 5, immagine 1 di 3 HTC Windows Phone 8S Logic Board Replacement, Flex Cables: passo 5, immagine 2 di 3 HTC Windows Phone 8S Logic Board Replacement, Flex Cables: passo 5, immagine 3 di 3
    • Remove the USB dock connector metal plate.
    • Open flex cable connectors:
    • LCD display flex cable
    • Menu buttons flex cable
    • Volume buttons flex cable
    • Touch screen flex cable
    • Power button flex cable
    • Pick up the vibrating motor and take out all flex cables except the LCD display flex cable.
  6. HTC Windows Phone 8S Logic Board Replacement, Logic Board Removal: passo 6, immagine 1 di 3 HTC Windows Phone 8S Logic Board Replacement, Logic Board Removal: passo 6, immagine 2 di 3 HTC Windows Phone 8S Logic Board Replacement, Logic Board Removal: passo 6, immagine 3 di 3
    • The logic board is secured to the display frame by two locking clips.
    • Use a plastic tool to release it.
    • Now remove the LCD display flex cable from its connector.
  7. HTC Windows Phone 8S Logic Board Replacement, Logic Board / Main Board: passo 7, immagine 1 di 2 HTC Windows Phone 8S Logic Board Replacement, Logic Board / Main Board: passo 7, immagine 2 di 2
    • HTC Windows Phone 8S Logic Board.
Conclusione
ZFix
Membro da: 12/09/13
195.943 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
329 Membri
1.452 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,149
