Introduzione
How to disassemble / take apart the device and change broken, smashed touch screen glass and LCD display.
Cosa ti serve
Panoramica Video
Switch off the phone.
Remove the SIM / memory card cover.
Remove any SIM and memory cards.
Use screwdriver torx T5 and unscrew the two screws at the bottom of the battery / back cover.
Use a Phillips #0 screwdriver and remove the 4x silver screws.
With a plastic tool carefully separate the battery from the logic board.
Remove the USB dock connector metal plate.
Open flex cable connectors:
LCD display flex cable
Menu buttons flex cable
Volume buttons flex cable
Touch screen flex cable
Power button flex cable
Pick up the vibrating motor and take out all flex cables except the LCD display flex cable.
The logic board is secured to the display frame by two locking clips.
Use a plastic tool to release it.
Now remove the LCD display flex cable from its connector.
