Salta al contenuto principale
HTC Warhawk Buttons Replacement
Cosa ti serve
  1. HTC Warhawk Buttons Replacement, Buttons: passo 1, immagine 1 di 1
    • Take the back cover off the phone and take the battery out.
  2. HTC Warhawk Buttons Replacement: passo 2, immagine 1 di 1
    • Take a SL#2.5 screwdriver and pop the black piece off shown here
  3. HTC Warhawk Buttons Replacement: passo 3, immagine 1 di 1
    • Take a T5 screwdriver and unscrew the two screws seen here
  4. HTC Warhawk Buttons Replacement: passo 4, immagine 1 di 1
    • Unscrew the two screws on the back of the phone with a T5 screwdriver
  5. HTC Warhawk Buttons Replacement: passo 5, immagine 1 di 2 HTC Warhawk Buttons Replacement: passo 5, immagine 2 di 2
    • Take the SL#2.5 screwdriver and pry off the back cover
    • The phone should now look like the second picture
  6. HTC Warhawk Buttons Replacement: passo 6, immagine 1 di 1
    • Take the SL#2.5 screwdriver and lift up the white connector at the top right corner of the phone on the side with the circuit board
  7. HTC Warhawk Buttons Replacement: passo 7, immagine 1 di 2 HTC Warhawk Buttons Replacement: passo 7, immagine 2 di 2
    • Next lift up the camera lens from the board.
    • It should now look like the second picture
    • Then lift up the circuit circled in red on the second picture
  8. HTC Warhawk Buttons Replacement: passo 8, immagine 1 di 2 HTC Warhawk Buttons Replacement: passo 8, immagine 2 di 2
    • Take the SL#2.5 screwdriver and pry off the volume buttons on the side of the phone
    • The circuit board should now be detached from the LCD part of the phone
  9. HTC Warhawk Buttons Replacement: passo 9, immagine 1 di 1
    • Next take the SL#2.5 screwdriver and pry the buttons off the phone and replace with the new ones
Conclusione
UW Stout, Team 5-3, Zhou Fall 2011 Membro di UW Stout, Team 5-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 769
