Salta al contenuto principale
HTC TouchPro MP6950 Battery Replacement
Cosa ti serve
  1. HTC TouchPro MP6950 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • This is the back of the phone.
    • Using your other eight fingers to cradle the phone, place each thumb on either side of the "Alltell" symbol.
    • Apply pressure towards your fingers, and then towards the top of the phone in a single movement.
  2. HTC TouchPro MP6950 Battery Replacement: passo 2, immagine 1 di 1
    • After the cover stops moving forward, remove it by lifting the cover away from the phone.
    • In this photo, you will see the cover being removed from front to back. The cover can also be removed by lifting it straight back.
  3. HTC TouchPro MP6950 Battery Replacement: passo 3, immagine 1 di 1
    • Simple photo of the back of the phone with the rear cover off.
  4. HTC TouchPro MP6950 Battery Replacement: passo 4, immagine 1 di 1
    • The small notch area is where the pressure to remove the battery will be applied.
  5. HTC TouchPro MP6950 Battery Replacement: passo 5, immagine 1 di 1
    • To remove the battery, firmly hold the phone in one hand.
    • Using a finger, or in this case a plastic pry bar, apply pressure to this location, and pull battery back towards you.
  6. HTC TouchPro MP6950 Battery Replacement: passo 6, immagine 1 di 1
    • Be careful when removing the battery. If it comes in contact with any liquid, the battery can be ruined.
    • Simply lift the battery out of the battery tray.
  7. HTC TouchPro MP6950 Battery Replacement: passo 7, immagine 1 di 1
    • Clockwise from the top: The removed battery, the rear cover, and the phone.
  8. HTC TouchPro MP6950 Battery Replacement: passo 8, immagine 1 di 1
    • If the battery is not working properly, water damage might be the culprit.
    • The small box on the right contains a white background with red hashes on top.
    • If the lines are sharp, there has been no forms of water damage.
    • If lines are blurry, or the background is pinkish, the has been water damage.
Conclusione
Tyler
Membro da: 08/27/11
26 Reputazione
1 Guida realizzata
Cuesta, Team 1-4, Zipperian Fall 2011 Membro di Cuesta, Team 1-4, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G4
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 274
