Salta al contenuto principale
HTC Thunderbolt Speaker Replacement
Cosa ti serve
  1. HTC Thunderbolt Speaker Replacement, Rear Panel: passo 1, immagine 1 di 1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt Speaker Replacement: passo 2, immagine 1 di 1
    • Lift and remove the rear panel.
  3. HTC Thunderbolt Speaker Replacement, Battery: passo 3, immagine 1 di 2 HTC Thunderbolt Speaker Replacement, Battery: passo 3, immagine 2 di 2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt Speaker Replacement, Rear Frame: passo 4, immagine 1 di 1
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
  5. HTC Thunderbolt Speaker Replacement: passo 5, immagine 1 di 2 HTC Thunderbolt Speaker Replacement: passo 5, immagine 2 di 2
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
  6. HTC Thunderbolt Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the two Phillips screws where the plastic cover was.
  7. HTC Thunderbolt Speaker Replacement: passo 7, immagine 1 di 2 HTC Thunderbolt Speaker Replacement: passo 7, immagine 2 di 2
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
  8. HTC Thunderbolt Speaker Replacement: passo 8, immagine 1 di 3 HTC Thunderbolt Speaker Replacement: passo 8, immagine 2 di 3 HTC Thunderbolt Speaker Replacement: passo 8, immagine 3 di 3
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
  9. HTC Thunderbolt Speaker Replacement, Rear Inner Frame: passo 9, immagine 1 di 1
    • Remove the two Phillips screws securing rear inner frame to device.
  10. HTC Thunderbolt Speaker Replacement: passo 10, immagine 1 di 1
    • Insert the plastic opening tool between the rear inner frame and the motherboard and slowly work your way around the device.
  11. HTC Thunderbolt Speaker Replacement: passo 11, immagine 1 di 2 HTC Thunderbolt Speaker Replacement: passo 11, immagine 2 di 2
    • Remove the rear inner frame from the rest of the device.
  12. HTC Thunderbolt Speaker Replacement, Speaker: passo 12, immagine 1 di 1
    • Flip over rear inner frame.
  13. HTC Thunderbolt Speaker Replacement: passo 13, immagine 1 di 2 HTC Thunderbolt Speaker Replacement: passo 13, immagine 2 di 2
    • Pry out speaker with plastic opening tools.
    • You have now removed the speaker.
Conclusione
Cal Poly, Team 19-45, Regan Winter 2013 Membro di Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Membri
24 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 622
