Salta al contenuto principale
HTC Surround SD Card Replacement
Cosa ti serve
  1. HTC Surround SD Card Replacement, Back Case: passo 1, immagine 1 di 2 HTC Surround SD Card Replacement, Back Case: passo 1, immagine 2 di 2
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC Surround SD Card Replacement: passo 2, immagine 1 di 3 HTC Surround SD Card Replacement: passo 2, immagine 2 di 3 HTC Surround SD Card Replacement: passo 2, immagine 3 di 3
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC Surround SD Card Replacement: passo 3, immagine 1 di 1
    • Separate the screen and back cover with the opening tool.
  4. HTC Surround SD Card Replacement, SD Card: passo 4, immagine 1 di 3 HTC Surround SD Card Replacement, SD Card: passo 4, immagine 2 di 3 HTC Surround SD Card Replacement, SD Card: passo 4, immagine 3 di 3
    • Look at the bottom right hand corner of the device and remove the silver tape covering the SD card slot with your fingers.
    • Insert the plastic opening tool directly underneath the orange surface below the SIM card until its removed from the surface of the device.
  5. HTC Surround SD Card Replacement: passo 5, immagine 1 di 2 HTC Surround SD Card Replacement: passo 5, immagine 2 di 2
    • To get to the attachment that the SD/SIM card is attached to; insert the plastic opening tool underneath the lower motherboard until it is removed from the bottom half of the device.
    • You will notice the SD/SIM card is attached to the lower motherboard by a yellow piece of tape. Remove the tape from the back of motherboard with your fingers.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 22
Tutti i Tempi: 223
