Salta al contenuto principale
HTC Rhyme Volume Button Replacement
Cosa ti serve
  1. HTC Rhyme Volume Button  Replacement, Removing Back Cover: passo 1, immagine 1 di 1
    • Slide the bottom back cover off of the phone.
  2. HTC Rhyme Volume Button  Replacement: passo 2, immagine 1 di 1
    • Locate the four screws on the plastic cover and unscrew them.
  3. HTC Rhyme Volume Button  Replacement: passo 3, immagine 1 di 1
    • Pry the sticker off from the sides.
    • You can use a metal spudger to do this.
    • Peel the sticker off with your hands.
  4. HTC Rhyme Volume Button  Replacement, Remove the plastic cover: passo 4, immagine 1 di 1
    • Remove the plastic cover using your hands.
  5. HTC Rhyme Volume Button  Replacement: passo 5, immagine 1 di 1
    • Remove the yellow ribbon.
  6. HTC Rhyme Volume Button  Replacement: passo 6, immagine 1 di 3 HTC Rhyme Volume Button  Replacement: passo 6, immagine 2 di 3 HTC Rhyme Volume Button  Replacement: passo 6, immagine 3 di 3
    • Lift up the blue flaps underneath the battery.
    • Lift up the black flap at the top of the phone.
    • Lift up the black flap at the bottom of the phone.
  7. HTC Rhyme Volume Button  Replacement, Remove the Motherboard: passo 7, immagine 1 di 2 HTC Rhyme Volume Button  Replacement, Remove the Motherboard: passo 7, immagine 2 di 2
    • Remove all 4 screws.
    • Carefully remove the motherboard with your hands.
  8. HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: passo 8, immagine 1 di 3 HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: passo 8, immagine 2 di 3 HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: passo 8, immagine 3 di 3
    • Pry the back plastic casing off with your hands.
  9. HTC Rhyme Volume Button  Replacement: passo 9, immagine 1 di 2 HTC Rhyme Volume Button  Replacement: passo 9, immagine 2 di 2
    • Use the tip of a screwdriver to push the button out of the panel.
Conclusione
Frederick
Membro da: 10/08/14
119 Reputazione
1 Guida realizzata
USF Tampa, Team 9-6, Leahy Fall 2014 Membro di USF Tampa, Team 9-6, Leahy Fall 2014
USFT-LEAHY-F14S9G6
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 288
