Slide the bottom back casing off, pulling down.
  • Slide the bottom back casing off, pulling down.
Aggiungi Commento
Using the plastic tool, pry underneath the top plastic cover.
  • Using the plastic tool, pry underneath the top plastic cover.
Aggiungi Commento
  • Using a metal spudger, pry up the plastic piece covering the motherboard, and remove the sticker.
Aggiungi Commento
  • Use a Philip #0 screwdriver to remove the four screws of the plastic covering the motherboard.
Aggiungi Commento
  • Using tweezers, remove the yellow ribbon by gently pulling on it.
Aggiungi Commento
  • Using the plastic tweezers, gently lift the blue flaps up.
Aggiungi Commento
  • Using your thumb, push the flap up on the top.
  • Using your thumb, push the flap up on the bottom of the motherboard.
Aggiungi Commento
  • Using a Phillips #00 screwdriver, unscrew the four screws in each corner of the motherboard.
Aggiungi Commento
  • Carefully remove the motherboard from the base of the phone.
Aggiungi Commento
  • Gently push the base of the phone from the frame.
Aggiungi Commento
  • Using the metal spudger, remove the battery from the base.
Aggiungi Commento
  • Using tweezers, lift the secondary motherboard from the base of the phone.
  • The speaker is located on the back of the board.
Aggiungi Commento
Conclusione
Kelsey Harris
Membro da: 08/10/2014
121 Reputazione
1 Guida realizzata
USF Tampa, Team 9-6, Leahy Fall 2014 Membro di USF Tampa, Team 9-6, Leahy Fall 2014
USFT-LEAHY-F14S9G6
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 256
