Salta al contenuto principale
HTC Ozone Motherboard Replacement
Cosa ti serve
  1. HTC Ozone Motherboard Replacement, Rear Battery Cover: passo 1, immagine 1 di 1
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. HTC Ozone Motherboard Replacement: passo 2, immagine 1 di 2 HTC Ozone Motherboard Replacement: passo 2, immagine 2 di 2
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. HTC Ozone Motherboard Replacement, Battery: passo 3, immagine 1 di 3 HTC Ozone Motherboard Replacement, Battery: passo 3, immagine 2 di 3 HTC Ozone Motherboard Replacement, Battery: passo 3, immagine 3 di 3
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  4. HTC Ozone Motherboard Replacement, Frame: passo 4, immagine 1 di 2 HTC Ozone Motherboard Replacement, Frame: passo 4, immagine 2 di 2
    • Remove the six Torx #5 screws that are securing the rear frame.
  5. HTC Ozone Motherboard Replacement: passo 5, immagine 1 di 3 HTC Ozone Motherboard Replacement: passo 5, immagine 2 di 3 HTC Ozone Motherboard Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
  6. HTC Ozone Motherboard Replacement, Motherboard: passo 6, immagine 1 di 2 HTC Ozone Motherboard Replacement, Motherboard: passo 6, immagine 2 di 2
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  7. HTC Ozone Motherboard Replacement: passo 7, immagine 1 di 2 HTC Ozone Motherboard Replacement: passo 7, immagine 2 di 2
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
  8. HTC Ozone Motherboard Replacement: passo 8, immagine 1 di 3 HTC Ozone Motherboard Replacement: passo 8, immagine 2 di 3 HTC Ozone Motherboard Replacement: passo 8, immagine 3 di 3
    • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
Conclusione
Marco Jokada
Membro da: 04/28/11
247 Reputazione
6 Guide realizzate
1Commento della guida
Where can I buy/find/get this motherboard? I have been looking for one for over a year now, thanks
Walt - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,668
