Salta al contenuto principale
HTC One X SIM Card Tray Replacement
Cosa ti serve
  1. HTC One X SIM Card Tray Replacement, SIM Card Tray: passo 1, immagine 1 di 1
    • Insert a safety pin or other small object in the small opening next to the SIM card slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
  2. HTC One X SIM Card Tray Replacement, Repair SIM card tray: passo 2, immagine 1 di 1
    • Cut a piece of tape/ paper approximately the size of your Sim Card and secure it to the back side of the Sim. Be sure to trim any excess.
    • It's important that you place the tape on the back side of the Sim Card as it will block the communication with the device if placed on the front side
    • Slowly slide the Sim Card tray back into the device. It should be a smooth transition, don't force the tray in.
    • If the tray is still loose you can keep adding tape/paper until it's no longer loose.
Conclusione
Altre 5 persone hanno completato questa guida.
Blain Abebe
Membro da: 09/22/14
766 Reputazione
3 Guide realizzate
USF Tampa, Team 4-3, Brown Fall 2014 Membro di USF Tampa, Team 4-3, Brown Fall 2014
USFT-BROWN-F14S4G3
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 6,950
